DIY Full-Race 3" Downpipe and Catback Exhaust System
Discussion in 'Intake & Exhaust DIY' started by squiggy, Jul 30, 2013.
  1. Dennis Rockholt
    Dennis Rockholt 9k Alll Day
    1,952
    Franklin, TN
    Vehicle Model:
    370Z Fairlady aka "Nismo"
    Body Style:
    Exactly! And removing the heatshield etc just seems like so much work. Even though, it really is not much work at all
  2. Full-Race Geoff
    Full-Race Geoff Well-Known Member
    65
    Full-Race, AZ
    clearly youve never been to a honda day event ;P my eardrums are bleeding by the end of day
    Dennis Rockholt likes this.
  3. Dennis Rockholt
    1,952
    Franklin, TN
    Vehicle Model:
    Body Style:
    Yep a lot of people run an open header or downpipe...
  4. DSpizzle
    DSpizzle Well-Known Member
    173
    Oviedo, FL
    Vehicle Model:
    Body Style:
    Has there been an issue clearing this bar? Should I just remove the bar? The exhaust does rattle on it... IMG_2969.jpg
  5. squiggy
    • 2018 Toys For Tots
    squiggy Cartographer
    10,769
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Hmmm...that looks like a new addition to the frame after the 2012.
  6. DSpizzle
    173
    Oviedo, FL
    Vehicle Model:
    Body Style:
    I think that you can reach the header bolts from under the car... at least 3 of them..
  7. DSpizzle
    173
    Oviedo, FL
    Vehicle Model:
    Body Style:
    I had to take it off to get the stock exhaust off.. Not sure if it has any purpose.
  8. Dennis Rockholt
    1,952
    Franklin, TN
    Vehicle Model:
    Body Style:
    Yes, I actually removed that bar. Because of the rattling, it was really bad haha
  9. squiggy
    10,769
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    I assume it is part of the suspension tweaks to try and tighten up the body roll.
  10. Dennis Rockholt
    1,952
    Franklin, TN
    Vehicle Model:
    Body Style:
    Agreed, It very well could be. Now that I am lowered I ahvent noticed a huge difference
  11. Full-Race Geoff
    65
    Full-Race, AZ
    if you want to retain that little piece of steel, just install 2 washers under it and reinstall. I have not found it makes any noticeable difference when kept in place or removed for any of the cars we've had in here, but spacing it down slightly allows the larger exhaust to fit just fine. hope this helps
  12. twister8008
    twister8008 Well-Known Member
    860
    Omaha, NE, but I am a Wisconsinite
    Vehicle Model:
    Civic SI
    Body Style:
    What size washers are needed?
  13. Dennis Rockholt
    1,952
    Franklin, TN
    Vehicle Model:
    Body Style:
    If you have the invidia N1 paired with this downpipe, the hangers near the exhaust tip will rattle up against the sheet of metal hanging down right behind it. I am trying to figure out what to do with mine now, I may just attempt to put some sort of rubber there to keep it from being noisy. Again, its only sometimes and not all the time. Just figured I would let anyone know with the same setup as me.
  14. twister8008
    860
    Vehicle Model:
    Civic SI
    Body Style:
    Just bought the other piece of my exhaust! :) Got my FR catback from @axionindustries. I can't wait for it to get here. Thanks to @squiggy for this awesome DIY! Hopefully all goes smoothly. Pairing it up to my FR catted DP.
  15. mbenson
    mbenson Active Member
    1
    How do you remove the windshield wipers. Is it just me but mine are like super tight on there i removed both bolts but i cant just take them off. Any suggestions please and thank you :D
  16. squiggy
    10,769
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    If you have removed the bolts, you just need to wiggle them a little bit or maybe pull the arm off the windshield first as if you are cleaning the windshield. They will come off. Even I was surprised at how they felt the first time I tried to take them off
  17. Tom's Si
    Tom's Si Well-Known Member
    163
    Sarasota, FL
    Vehicle Model:
    Body Style:
    Just dont force it or you'll be ordering a windshield lol
  18. W3R0
    W3R0 Well-Known Member
    169
    WA
    Vehicle Model:
    Civic SI
    Body Style:
    ^^what he said, take your time DONT try to pry off windshield wiper with anything!! Just wiggle wiggle and wiggle
  19. squiggy
    10,769
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    Not sure what you guys are talking about. Just flip the wipers up and wiggle. If you manage to break your windshield, you have done something severely wrong and shouldn't be attempting to even fill a gas tank.
    Quit trying to scare people.
    SlySi likes this.
  20. NoTorque
    NoTorque Active Member
    40
    The wipers were kind of tricky for me but then all of the sudden they just came loose without me even doing anything it seemed. Just light pressure it all it takes and then poof they come off!
    Ralph619 likes this.
Share This Page
