Tools Needed:
Oil filter wrench/remover of your choice
Jack and jack stands or ramps
Oil drain pan
Funnel
17mm socket
Torque wrench
Supplies Needed:
4.4 quarts of 0W-20 oil
Oil filter (part number/size will depend on brand you choose)
Rag
New crush type washer for oil drain pan bolt
Optional:
14x1.5 Magnetic drain bolt/14mm socket (if putting a magnetic drain bolt in)
Steps:
1. Jack car up and put it on stands or use ramps.
See the following thread for details if necessary:
http://9thcivic.com/forum/threads/2...your-car-and-where-to-place-jack-stands.5759/)
2. Release hood by pulling latch inside the driver’s side door under the dash.
3. Prop up hood by using one of the two locations as shown below.
4. Locate oil dipstick (left) and oil filler cap (right).
Remove oil filler cap and set it off to the side.
5. Locate the oil drain pan bolt and oil filter.
Place oil drain pan under both the drain plug and filter. Make sure you allot for how far out the oil will arc at first.
6. Loosen (only) the oil drain pan bolt with the 17mm socket. Finish removing the bolt with your fingers. Due to the placement of the oil filter on this engine you will need to wait for the oil to drain first and then put the drain pan bolt back in with a new washer. Do not tighten it all the way right now.
7. Remove the oil filter with the wrench/remover of your choice. Make sure the drain pan is underneath the filter as oil will come out. See pics below for my preference of remover. I find that most traditional wrenches are too small to really grip the small filters used on Civics.
8. Before putting the new oil filter on, make sure you dip your finger in some of the new oil and lube up the ring seal on the filter. I have marked a little section to show the difference with and without oil on the seal. Screw on and tighten by hand.
To be continued in next post...
Oil drain pan
Funnel
17mm socket
Torque wrench
Supplies Needed:
Rag
Optional:
Steps:
