12civic5speed
i am so scared to cut the blower cover that is the only hold up on me doing the
install
install
The "template" is inside the instruction manual, but there have been plenty of people that have said that they never touched the blower cover and the light came through just fine.some one should make a template or something
You only need to remove a small portion of the blower cover. The template in the kit is helpful to get an idea of what to remove. The cover is made of rigid plastic and cuts pretty easily with a hack saw. It would be very hard to make a major error doing this. I say go for it. The lights are a nice factory touch you can add with very little effort.i am so scared to cut the blower cover that is the only hold up on me doing the
install
College Hills Honda is a dealership and can't control the quality of product Honda puts out. Whether you choose to buy two kits or not is entirely up to you.so to put it in conclusion it wouldnt be as bright withtout the clear lense from the blue one. and if we wanted to be more bright or have more light around the bottom we would have to buy 2 kits which would be 180 total. hmmm is there a way we can inform collegehillshonda about this? also if we drill a hole around that plastic thing that covers the lense would it be bright like the one royce did? or do we really need to buy the blue kit? sorry for bringing up an old thread.
I also drilled holes and I am happy with the light but I'm sure the clear lenses would look better, but I was happy with the light output after drilling holes.
Nope.do you need to drill hole in th blue light set up
It's supposed to be the same, although there are separate instructions for the non-Si:will this diy work for a ex?
There are photos of the cover in the first post. Is that what you meant, or...?so i didnt cut my blower motor cover anyone got a pic of it cut so i can tell a diff
