- 57,160
- 24,334
man ...not going well
Me too.Not a good day to be an 8th owner.
Thought you meant the bimmer, Rich. Hopefully nothing bad happens in September if you bring the E30
Gotta tow the car back home. Clutch is gone. Mike is having to reconnect the exhaust on his car at the Dragon's den
Should have brought the bimmer.
I should be up there between 6am-7amMorning run sounds good. What time? 7 or whenever Matts arrives.
. Might contact killboy to see if he captured the plate in a pic.
Damn that sucks. I'm sorry to hear about the car troubles. I guess you shouldn't have listened to me and gone with the Bimmer.
When I push in the clutch it makes a noise and sometimes I can't push the clutch in all the way. I think something happened to part of the clutch assembly.Silly question Richard. Sure it's the clutch and not stretched cables? Seems weird for the clutch to just go without warning.
Check the CMCWhen I push in the clutch it makes a noise and sometimes I can't push the clutch in all the way. I think something happened to part of the clutch assembly.
I made it home with a limping car. Didn't tow it. I have the EM1 CMC on it. Is there something in particular to check? Everything works fine with the car off. It is only when the car is running.Check the CMC
153k miles. Should be time for a change.throw out bearing or the clutch fork may be bad also.
Thanks to Nomar06 for being a chauffeur.
