- 57,156
- 24,332
I think most people have bent the exhaust hanger some to get it to drop down a bit.
Looks good! Have you thought about tinting the taillights?
i hope it isnt ticket worthy thoughgot the rear sway bar in![]()
love it man and i do the same thing. my girlfriend hates it because she gets motion sick and i push it through EVERY corner![]()
does yours make noises when you go over bumps?How do you like it? I like pushing my car to see what it can do around some of my favorite corners to and from work lol. With the Progress 22mm I can hug corners pretty good.
Lmao! My GF hates it too. She yells at me all the time.
yeah its a clunk
hit all the bolts with an air gun
Don't let him do that. The torque specs on these bolts are only between 28 and 32 ft-lbs. If it is installed correctly, it shouldn't be hitting anything.
could that be it?There was a small packet of grease for the rubber bushings that should have been used. If it wasn't, you may be getting some creaking. With proper install, this sway bar will not make any noise. Double check fitment and properly torque all bolts and you should be good.it dosnt sound like its hitting anything its hard to discribe. also we didnt grease anything..could that be it?
