AlienPrime
Adding this for squiggy and FooBird
Just auto windows in passenger module. how it would be wired, since OEM switch won't power with their sensor-type relay
the inputs on the window cannot take feed from a auto switch. even when i switched leads on passenger and driver window buttons. passenger window did not work automatically
i thought it was just a simple switch, but there is a relay that holds on open/close until the window is all the way open or closed
if i were to make it work, i would simple run a 12v, 8 second time delay relay. and have it hold power at 12v for 8 second interval. once the window is all the way down the window would stop of course.
this is not how OEM does it tho :/
plus it will burn the motor in the window faster because it may have a second or two when the motor is running still trying to open or close the window once it was already open.
