sk8nava
Yes that makes sense, but are we suppose to fuse tap into #12 and if so, with what amp fuse. There is a 20a already in #12 so what should I use for the relay?
i think the relay is already coming with 40A fuse, no?Yes that makes sense, but are we suppose to fuse tap into #12 and if so, with what amp fuse. There is a 20a already in #12 so what should I use for the relay?
great 30a inline and relay is rated at 40a i assume?Well it comes with a 30a fuse for the battery..
I put a 20 in the fuse tap. I don't think we need two fuses because that slot is empty.....well, it is for LX. I am actually in the process of installing them but they are not working yet. I think it is either one of my grounds (drivers side) or the fuse tap into #12 in the engine bay fuse box is not correct. The video says we should tap into the ignition wire (fuse). Do you know which one that is? I gotta check the fuse chart again. FK.....I don't know why it has to be so difficult.Huh..?
I'm just trying to figure out what fuse to put in the fuse tap for the fogs in #12.
I think what I'm going to do when I get the fogs in is just fuse tap a 10a along with the 20a that goes in the #12 for the fogs. It seems like all we need is something that is ignition sensed just by looking at Pauly99to17 picture. It shows t-taps on the ignition and batter wires, but I hate those, so I will will run a wire through the firewall to the battery for constant using a terminal ring and not the t-tap, then connect a fuse tap to the ignition wire and find something in the fuse box that has 12v when the key is on and just tap it there with two 10a fuses assuming that the slot is empty or just tap it with one 10a fuse if it has a fuse already there. I'm about to go volt check right now, I'll let you all know.
Clear as mud.great 30a inline and relay is rated at 40a i assume?![]()
Do one for a radar detector please![]()
did you use two fuses?Okay. Gotcha. I ended up running the fuse tap into the cabin and tapped into #43 which is for one of the power windows. It also takes a 20a fuse. Success!![]()
Well, for this one yes because there was already a 20a fuse there so I knew I had to have two: 1 for the window and 1 for the fog lights. The tap in the engine bay to #12 didn't make sense to me to have to put two fuses because that slot was empty so I thought I just had to put 1 fuse into the tap for the fog lights.did you use two fuses?
I still don't understand why that tap needs 2 in #12 when it was empty, but not to worry.Well the #12 requires a 20a to go in that slot if you had fogs hooked up...so if you were to tap into that you would have needed a 20a along with a 10a or whichever amp fuse.
Anyways you went ahead an tapped into the #43 in the cabin with a 20a and you are running 2x 20a in the fuse tap?
