mpheng
Looks so aggressive now, did you have to get an alignment after the drop? Also any scraping? haha
Thanks! No, no rubbing at all which is the main reason I chose The Eibach Pro Kit springs. It's a significant drop, but leaves enough space so I don't have to worry about rubbing. The ultimate test was this section of highway that i drive every day to work that is really bumpy and wavy. I drive it at 125 km/hr and no issues at all. Nothing when I went over the bumpy train tracks either.Looks so aggressive now, did you have to get an alignment after the drop? Also any scraping? haha
Not very good, but it's not a problem for me. They are more for aesthetics than practicality.hows the light output on the roads with the led fogs?
FWIW my rear camber was marginally out of spec after the post drop align - not enough to worry about. The front was all good. Of course the toe had to be adjusted. (I'm also on Eibach Pros)I will get an alignment in 2 weeks once everything has settled
Thanks. Ya, it doesn't feel out of line at all, but I'll take it in anyway.FWIW my rear camber was marginally out of spec after the post drop align - not enough to worry about. The front was all good. Of course the toe had to be adjusted. (I'm also on Eibach Pros)
Neither did mine, but was toed in a ton front and rear - actually drove pretty nice before the align.Thanks. Ya, it doesn't feel out of line at all, but I'll take it in anyway.
"Ez lip", or as some people call it...the Home Depot lip. It can be done with 3m tape and a rubber garage door seal.What front lip do you have on?
Thanks, does anyone have a DIY on how to do the home depot style?"Ez lip", or as some people call it...the Home Depot lip. It can be done with 3m tape and a rubber garage door seal.
Like Webby said. I went to Home Depot and found some garage door weather stripping and it was pretty close, but not exactly the same as the EZ Lip. Plus, it doesn't cone with 3M double sided tape. Might be easier to just get the EZ Lip from their website.What front lip do you have on?
