LiL K BoY
Hay if its not any trouble do you think you can hook me up with links to your setup I really like the black and red look and its about time I got a ss
The steps would be identical except for putting on the adapter. With both you will have to remove the entire assembly.Is there a DIY for a short shifter?I've seen one for the short shift adapter but not the shifter itself.I've had the TWM shifter for a while and just ordered a Moddiction Anvil but not completely confident about installing it .Anyone have any problems while installing the shifter?
That's the part I'm most worried about because I read if you break that part Honda doesn't sell it without the shifter assembly,not sure if that's true though.I removed the shifter cup by myself although it does recommend 2 people. You need to use paper clips to hold the tabs open so that you can pull the cup out. I used a screwdriver to pry the tabs out. Not really an easy process.
Thanks,The tabs on the cup are thicker and stronger than I thought they would be,which is a good and a bad thing.They're harder to pry out than I expected but I think it would take quite a bit of force to break them.I went in at an angle using a precision flathead screwdriver one at a time and when I got the tab far enough out put the paperclip in to hold it.I marred the hell out of the clips because the thickness of them made it hard to get the screwdriver behind them but it didn't hurt them.Once I had all 4 tabs secured with the paperclips my friend grabbed the shifter and yanked it out with no problem.I had help but it can be done by one person and it's SO worth the money,I love the way it feels.^^^Looks great! Nice job. Any tips on getting the black cup out?
Very nice setup! I went with the Buddy Club Short shifter and Hybrid racing cable bushings and base bushings. The large cable bushing has a bearing race in it to better accomodate shifts. I don't know why, but mine is not an inch higher than oem, as someone posted. The shifter is curved to be a little closer to the driver though. I have my knob screwed all the way down, too. The shifts are short, precise. There is no damping sensation at all.View attachment 27159
@webby you da man!only a few options out there
http://9thcivic.com/forum/threads/billetproshop-short-shifters.7226/
http://9thcivic.com/forum/threads/twm-shifter.7474/
http://9thcivic.com/forum/threads/buddy-club-quick-shift-kit.7775/
https://acuityinstruments.com/colle...rt-shifter-for-the-2012-2015-honda-civic-1880
