View attachment 13686ok so it came in but all over the box it says 06-11 kinda worried that im gonna go to put it on and not have everything i need.
Over steer vs under steer .......... It is said that by adding a thicker rear sway bar will work towards keeping our cars from under steering .... and to add a more thicker sway bar to the front end will make it under steer again.
So what is under steer and over steer ....... When pushing the limits of traction around a turn you turn the front wheels in the direction you want the car to go, but instead of the front wheels sticking to the ground they start sliding toward the out side of the turn from loose of traction..... It can happen with front or rear drive cars, but since we have frt wheel drive that doesn't leave us with much to do to save it.
Where as with over steer.... that means when going around a turn pushing it beyond traction it will make the rear wheels lose traction..... and having a front wheel drive car will allow us the ability to have more control during the rear slide by applying counter steer and more power to the drive wheels.
Under steer is also referred to as "Pushing"(as in pushing the front of the car in a straight line while trying to turn it).
I know that there are a lot of you peeps that know all this stuff, but for the sake of the ppl that don't, this is for you.
Just a little help for our friends.
Adding a bigger front sway bar will just throw it back to the way it was before you added the rear. These cars are already really stiff up front and do not benefit from replacing the front sway bar.
@dimsum .... "Some people still recommend upgrading the FSB, because it will make the car feel more "balanced"...don't really know what that mean to be honest. Want to see what you guys have to say?"
It varies on different cars, and our Civics don't need it...... That's if you would rather have your rear slide instead of the front..... So by adding a stiffer rear it will be "Balanced" ........... That's not to say you can't put an "even thicker" r-bar, and then add a little more to the front. But being a DD it would be like taking steroids when you can already lift 300#.
Plus you'd not only be guessing how much for each end, it will be difficult to find the right parts.
These equations have come from the Civic racing community that went though the trial & error for you.
You're good the way you are...... Some with 2012 Si's have even gone to 24mm rsb's...I guess also, knowing that the 2012 Si came with a 18mm front, and I believe Honda upgraded the 2013+ Si's with a 21mm.... again...rather than getting the eibach 24 mm front, would it be more cost effective & more beneficial to just upgrading my FSB to the 2013 FSB?.....![]()
Yes they upgraded the front sway. This can be combated by upgrading to the 24mm RSB from Progress for '13 and up. '12 and owners tend to put the 22mm on the rear.
The concern with a bigger sway is for inexperienced drivers as it can cause the rear to kick out sooner than expected resulting in loss of control.
