So I've been experiencing some clutch noise in my 2012 Civic SI for the past month or so. It happens when I'm starting from a dead stop. It's like a grinding type of niose once the clutch reaches the friction point. I had it in the dealer today for an oil change and to replace something with the driver door due to a recall and I got them to take a look at it.
They said it could be springs or something inside the clutch and they'd have to order in the part. They also said that it should be covered under warranty however, if they get in there and see that there is "a lot of scorch marks" and "signs of abuse" that I'd be on the hook for the repair.
Sorry for the cut and paste, but here it's goes. This is a request from Honda to notify them if a car comes into your dealership. They want techline involved from the get go.
To: All Honda Service Managers/Advisors
RE: Request for Visit/Parts: 2012 Civic Si M/T Clutch Noise
Print this iN message and provide a copy to the Shop Foreman and all Service Advisors.
Background
American Honda (AHM) is investigating certain 2012 M/T Civic Sis with a complaint of a clutch noise when engaging the clutch in 1st gear or when accelerating from a stop. The noise can be described as grinding, squeaking, groaning, rubbing or metallic. To fully understand the cause of this condition, AHM would like to inspect the vehicle prior to you attempting a repair of any kind.
Qualifiers
AHM is interested ONLY if the vehicle meets the following requirements:
1. Vehicle must be under the New Vehicle Limited Warranty (3 years or 36,000 miles)
2. No extended warranty
3. No previous clutch repair
Action Required
If you have or know of such a vehicle, please call Technical Research & Support (TRS) Group at 800-880-1072. TRS will need to record certain vehicle information and provide you with further instructions.
