Mikeorock
Id like to try to hide the intercooler a little better
looks mean man. what kind of headlights are those?
http://9thcivic.com/forum/threads/procivic-projector-matte-black-led-headlights.8925/looks mean man. what kind of headlights are those?
thanx webbyhttp://9thcivic.com/forum/threads/procivic-projector-matte-black-led-headlights.8925/
but if you flip the bulb upside down the output changes. It's discussed later in the thread
http://9thcivic.com/forum/threads/new-projector-headlights-for-all-9th-gen-civics.7956/thanx webby
Yea spec d.. I havent flipped the bulb .. Bit other then that it looks cool.. People always complimentinglooks mean man. what kind of headlights are those?
the mesh wasn't too bad, just time consuming over anything elseWas it hard putting in the mesh?? How did you do it??
Any pointers on how?? Yours looks professional.. Im trying to figure out how to do it nicethe mesh wasn't too bad, just time consuming over anything else
Also,, i am about to order a mesh grill.. The i dont want to make the intercooler very visible.. The differences in the ones i want are 60% air flow and 77% air flow.. I wonder how bad it will affect performancewell what i did was measure the hole, then cut the mesh with about ~2 inches extra on each side. Then just lay it down flush with the tabs that hold in the original piece and carefully start cutting very small holes JUST for the tabs to fit through (so little smaller then an inch long and only like 1/4 inch wide). So then by the end of the cutting you're left with a sheet of mesh that has holes in the shape of of the grill. Then set it in there and push the mesh all the way down and very carefully start bending the excess mesh to fit so that it sorta hugs that lip. Then you can find whatever works for you to glue it down, but Amazing Automotive Goop works very well and i caked that **** on there. It takes a few hours to dry, but it dries clear and it's very tough.
