hotdogjohnny
wow. loosening is from left to right using my photo of your shifter. i guess you have to go medieval and put a vicegrip on it and turn fro the driver side of the car to the passenger side. Should loosen up.
no problemYeah luckily I work at a honda dealership so I'm going to have my buddy look at it in a bit. I was just hoping I could get it all figured out myself. Thanks for the help by the way!
@webby @squiggy
Ok, I am trying to install my new extender...my initial shift knob installation was easy. Please find the thumbails which show my current issue. When installing the extender, I tightened it down fine and added the knob on top. Well, the knob doesn't line up correctly so I went to tighten from the base piece after loosening the knob up to the correct position. I have no way to tighten the base piece. The entire part from the black rings down to the metal separate from the rest of the shifter spins in both directions freely. I am at a loss right now. Am I overlooking something or did I possibly over tighten? Any help would be greatly appreciated.
I also snapped the black clip this time...but I will address this later...
View attachment 45990 View attachment 45991 View attachment 45992
In other words it's supposed to spin and I'm going crazy? HahaThe retainer is not meant to be threaded all the way down the shift lever. The stock retainer is designed to work in tandem with the stock knob. The two surfaces stay together because they are threaded towards each other.
Dang, I guess I just never noticed it spun before. How am I able to line the knob facing forward without having the ability to tighten the bottom?If you aren't using it with a knob that mates with it, then, yeah, it is going to spin.
Oh wow...the retainer. I put the retainer between the knob and the extension piece. Wow haha. Now I have a tall thin extension piece thoroughly tightened and will be tricky to back off.Only thing I can think of is to look for an aftermarket retainer.
I feel you. I saw your comments and have the exact same issue. My last post wasn't accurate, I have the retainer in the right place and everything.No the nut won't spin up or down. That's my whole problem..
@squiggy Last question, I promise. I got a bit confused but I understand what you mean now. I never used the retainer piece, actually, as I found it on the floor mat after the fact. Regardless, because I tightened the aftermarket extender all the way down, the two parts are now threaded together and I have no way to safely remove the extender if I wished to? I appreciate the help.
