Kevv_Si
Well fellas car is running! Downloading vids to YouTube now!
Try nowvideo is private
Exhaust. I think it may be the seals. Turbo is under warranty anyways ...was brand new sealed in boxwhite smoke coming out from a turbo or exhaust? Check your seals
Mine was smoking a medium amount at idle tho then a lot when I reved it. But I never actually got the car moving. Drove it and let it idle for like 8 minutes with 0 smoke.I had a little smoke when I first installed my downpipe, apparently from some oil/grease that was on the flanges to keep them from rusting. Maybe it was the way with you?
I think I just needed to let the oil pressure rise and let the turbo feed and drain.I had a little smoke when I first installed my downpipe, apparently from some oil/grease that was on the flanges to keep them from rusting. Maybe it was the way with you?
Ordering it this Friday.Did you upgrade the clutch? So far it sounds good.
