ac3jason
Is there a difference in performance or what they do? The shorter one vs the longer one.
Yes you can use DOT4 fluid, i used Synthetic Clutch Fluid from AutoZoneSo to who ever has done this.. Can you just add dot 4 brake fluid?? Or would you have to fully bleed the system in order to use dot 4...
Im pretty sure its ok to mix but injust wanna be sure
Good Bye CDV!
About 20mins
Is it the same process for a 2015 civic Si coupe?
Thank you sir! The fun continues! is the PRL SS clutch line the best to go with right now?
