sunofwolf
- 178
- Vehicle Model
- Civic SI
- Body Style
- Coupe
too expensive,you got a turbo, I use 0-40 mobil one European formula in the 1.25 jug. 0-20 is the best in late honda's
_________________you forget that Honda engines are different then a lot of engines and was designed to use 0-20 or 5-20. I don't think a ford v8 is any where near a high rev Honda. If you run thick oil in a Honda it will burn less oil, but then start to gunk up inside. Much better to burn some oil up then sludge it up with thick oil. The ford v8 is designed to run on 5-20, but oil is getting burned up. I added some 0-40w mobil 1, now its burnup a lot less oil, it has 160,000 miles on it which shows ford does make a good engine and it s beat to hell and back-still going ok. Mobil 1 0-40 European blend is a top of the line, Mobil has to follow different specs and can't cheat because Europe wouldn't allow it to be sold otherwise.
Like a report someone’s had done?@webby... can you help locate one of those PDF Blackstone reports as a sample? Thanks amigo. (And if you can't I might be able to upload another one)
Cheers!
Was that a Honda engine that blew up, how many Milles? Suks getting a Lemon. How much did a engine cost you?@Bruce Bartlow awesome sauce, thanks for the info I am going to look more into it now. I am going to do an oil change soon to replace the oil in my replacement motor since my last one went BOOM. I don't think the person who had it before took good care of it and I am curious to see how it turns out.
Should have bought the car from a old lady or guy who rarely drive's, last two cars I did that.Was that a Honda engine that blew up, how many Milles? Suks getting a Lemon. How much did a engine cost you?
He isn’t stock. He has a turbo and was data logging for his tunerWas that a Honda engine that blew up, how many Milles? Suks getting a Lemon. How much did a engine cost you?
Need pictures outside on the ground lol
Perfect, thanks Web! My first MTF test is attached. It gave me the heads up that I was using the wrong MTF for an LSD.Like a report someone’s had done?
http://9thcivic.com/forum/threads/blackstone-lab-oil-analysis.6491/
