- 55,591
- 23,843
buy a good toilet
Those toilet are supposed to be able to suck down a bucket of golf balls too.I have news for you. There are toilets that do 1 gallon flushes. Kohler makes 1 gallon, 1.28 gallon, and they also make duel flush toilets. Push one lever and it flushes 1.1 gallons, and push another and it uses 1.6.
https://www.us.kohler.com/us/Bathroom+Colors/article/CNT123600001.htm
get a toilet that is actually engineered to flush properly & you will have no issue.
I don't know who tells you false information. You don't need a RMM to run 3" DP it does help with wheel hop a little and the strength of the 3" is the same exact as the 2.5" just because you add .5" does not mean it will instantly be weak.Ya, I saw that dyno too on the rv6-it leave's out how they tested it. But my theory is actually these two mods should work very well together. You add more air and add less restriction with the exhaust, this combo should make a major difference with a etune. The etune brings these parts working together correctly making the engine quite a bit more power around 200HP. That's about 15% more. I like that rv6 200 metal catted piece. rv6 has a racing cat that saves weight and is not very restrictive like those two very ugly stock cats. The rv6 has been tested very hard and doesn't fail. I am concerned of the 3" downpipe's especially on installation and weight and extra stress on these pipes-they have to have a rmm too. Also the 3" downpipe might be very noisy. Just so many thing's can go wrong.
You are also not going to get 200 whp with the CAI and a 2.5" catted DP maybe 175-180 whp.
That was my understanding as well. It's not due to the mount not being strong enough, but due to there just not being enough clearance after stepping up to 3".Everything I've ever read says you need the RMM so the Down pipe doesn't hit the frame.
add 3HP due to acuity being better then subtract 3HP due to running a cat-this should be the exact HP for my proposed mods.View attachment 59959
206 with q300 so you might be able to squeeze 200 whp out of the 2.5" DP but I also don't know if that is catless tho.
This looks like another vote for the rv6 downpipe with just enough clearance 1/2 inch more than the 3" downpipe.That was my understanding as well. It's not due to the mount not being strong enough, but due to there just not being enough clearance after stepping up to 3".
