sunofwolf
- 178
- Vehicle Model
- Civic SI
- Body Style
- Coupe
That is the oem sensor for the si and every other trim civic.switching TNPS sensors, did one sensor. see pic -it has a number. Does not work on SI. the tire shop is switching the sensors for free!![]()
I am going to go to honda dealer with the new sensors and make sure these new one's are OEMThat is the oem sensor for the si and every other trim civic.
42753-TR3-A81
https://www.hondapartsonline.net/oem-parts/honda-sensor-assembly-tpms-42753tr3a81
And some TPMS aftermarket sensors such as this one don't work. Even though the part maker say it does. Note amazon has a close up pic of a OEM sensor and they don't match. This is beyond aggravating.there are TONS of companies that make sensors that are compatible for pretty much every make/model of car. If an oem sensor is say $50 a piece, you can usually find 20 other companies selling a compatible sensor for 20-40 dollars a piece. You can find countless companies selling tpms sensors that work with your car.
I’ve never seen one person have issues with reprogramming at 3rd party tire shops like discount tire with aftermarket wheels and aftermarket sensors.
No one on the forum has posted issues, and you can clearly see how many people run two sets of wheels or have aftermarket wheels. As for amazon, I have no clue on those reviews. Someone could be buying incorrect stuff for their make/model/trim or junk. The 12 is the same as the 13. The 2014 doesn’t have sensors in the wheel. It uses the abs sensor to calculate tire pressure at each wheel based on the number of wheel rotations.perhaps you didn't look because I found plenty of people having problems with the 2013 honda si wheel sensor's.
Facts- the discount tire direct sensors don't seem to work with the tire shop scanners and Main Honda computer. Its possible a blown fuse-it has two somewhere. When the key is on the dash shows no sensor reading. I don't know what's wrong.Those sensors from tire direct are not made any more perhaps the part maker knows they don't work
Go to amazon look under 2013 honda civic-plenty of problems there with wheel sensors and this certain year not sure about 2012. it looks like they fix the problem in 2014! it's quite obvious to me honda screwed up the software and left it to me to sniff it out.
