Mine currently at my house is going between -110 & -113
These are the 4 verified Verizon cell towers near me....
Doesn't even cover me..
Covers me but I'm in the green/blue area.
Doesn't come close to me.
So close but still probably would be slow..
Talk to Verizon/att/Tmobile about boosters. It’ll amplify your signal. If you can show there is an issue they’ll send you them for free, or free with a rebate etc. At least they used to offer them that way. It’ll end up being plugged into your router and I believe all of them need line of sight to a window for 911 service.Cell phone signal strength is measured in decibels (dBm). Signal strengths can range from approximately -30 dBm to -110 dBm. The closer that number is to 0, the stronger the cell signal. In general, anything better than -85 decibels is considered a usable signal.
Current as of this post I'm at -118 dBm. It went down to -110 but is at -118.![]()
@fahnix - did a few tests today.
* Airplane mode ON w/ WiFi ON (Verizon 4G LTE data disabled) - able to send pictures via MMS quickly
* Normal Setup (WiFi on / 4G LTE on but everything should default to WiFi) - enabled SMS/MMS via FB Messenger and pictures send quickly.
There you go. Sounds like it's finally doing what it's supposed to. Maybe something was going on in your area when you were having issues before. Who knows. They'll say it was something on your side. Cause you know, that's just how they are.![]()
