- 10,347
- 7,026
- Vehicle Model
- Toyota Tacoma TRD Sport
- Body Style
- @bootyluvr hates hatches
Win7 Pro. The "dos" looking screen is all black and just the _ blinking.
Downloading the program now.
Dell got a bad rap a few years back, which is still haunting them, because they used a different supplier for capacitors. They got a really good deal it seemed on price but, the manufacturer had copied the internal chemical makeup of the caps and since those are highly guarded industrial secrets they were off just a little. So.... Dell loads several thousands into hundreds of computers and everything seems fine... until caps start melting, bursting, destroying other parts, and so on. It generally took a couple years so people were out of warranty and super pissed at Dell. Many of the Dell horror stories can be attributed to said incident although its not a widely known story.
The way most computers work today, the BIOS provides you an option to boot from USB or other Removable Devices. If the BIOS sees an external USB drive or media card installed AND that drive or card is "bootable", usually meaning one or more INI files made it's way onto it, then the computer will see that device as a boot option. Since most computers will put that USB drive or media card on top of the boot list order, meaning it'll pick that device first instead of the local hard drive, the machine will try to boot from it. If it turns out to not be a bootable device, then the computer won't know what to do next and will stall at a blinking cursor.Comp booted up fine today with out the card in the slot. It didn't use to do that.....
The files are usually hidden, and even though your BIOS is set the USB to #3, it can easily bump it to #1 on it's own without any intervention...it just depends on the type of BIOS.There is nothing in the card. I only have pics in the card and they get deleted off the card once they are put onto the comp. Boot sequence is always 1. hard drive 2. CD 3. USB.
I will double check the card but there should only be one folder since the camara adds a folder where the pics get dumped into.
