Bruce Bartlow
Late apex everything
- 1,599
- 865
- Vehicle Model
- Rented a C8 for a week (what a monster) ended up buying a TLX. Beautiful car inside and out. Killer stereo. Handles better than it should given its weight. Not my dream car, just a Honda Accord in a tux.
- Body Style
- Sedan with the backseat of a two-seater
^^ they made a flashpro unit for the 2006+ r18 engines (non-si models). There are some ignition changes between the 8th/9th, plus the 9th has econ mode. Maybe the r18 in the 9th will get a flashpro relatively easily.
Possible changes in fuel mileage will be interesting as people reflash or get the toned down dealer update (accessibility is still spotty) ... I've heard to expect no change to perhaps 1 - 2 MPG (from Hondata) although there is no tweaking of the a/f mixture. The bottom line -- If it increases gas mileage and power, which is what Hondata has done, why didn't Honda just do that in the first place?
But so far in a month I've got a whopping 21 miles on it. Can't stand the rev hang... and "over rev" (as some call it) whereby the engine continues to accelerate even after you've released the throttle. It gets more complicated because the reflash solution could be used to deny warranty coverage. Then I start reading about oil consumption -- yikes! This is almost the same 2.4 my 2009 Accord has (which doesn't burn a drop) so I'm wondering what's up with that. I'm almost afraid the drive the thing!
