Transmission oil analysis results are in! This is from the Honda MTF I switched to after concerns about the AmSoil. So far, it seems as if it was a good idea to abandon the AmSoil.
Hey @Bruce Bartlow!
Hey @Bruce Bartlow!
Hey @Bruce Bartlow!
Squiggy, Thanks for running the UOA. To be meaningful, you should now run Amsoil MTF for 8K and see what the metals look like. If not we will never know if the run from 6K to 10.5K was residual break in.
____________Transmission oil analysis results are in! This is from the Honda MTF I switched to after concerns about the AmSoil. So far, it seems as if it was a good idea to abandon the AmSoil.
Hey @Bruce Bartlow!
______________Can I use royal purple mtf or should I go back with honda mtf
So I have a 2012 LX with a 5 speed manual. I don't believe I have a limited slip. Will Amsoil eat it up. I have 60k miles. The minder is telling me I need to change to 70k miles. I think I'll do it sooner and in the future change more office. I'll get more practice.
I did 5k miles engine oil changes for the first 20k miles then went to 10k changes still before the minder. But my driving is cruising at 60 to 65 on state highway.
The Honda dealers are 90 minutes away. and never open when I am around. I spent the first 50k miles using Honda oil. I can get Amsoil at the NAPA.You don't have a limited slip in yours. I'd honestly just stick with the honda mtf.
No Amsoil will not eat it up.
I am curious to see the results after having a bad lab using AmSoil and being forced to switch back to OEM.Despite being a long term Amsoil user (and dealer) I discontinued the use of Amsoil's synthetic MTF after disasterous lab results came in.... twice. I went back to Honda's OEM. No complaints.... and labs eventually returned to normal.
In the search for better protection (i.e., synthetic) and smoother shifting, I am now trying the Royal Purple MTF shown here:
http://www.amazon.com/Royal-Purple-...d=1424566065&sr=8-1&keywords=royal+purple+MTF
So far I'm impressed with the shift quality. Very impressed. First, the notchiness is gone, suggesting less metal-to-metal contact. But what I really want to know is how it protects. So after 10,000-15,000 miles and a series of torture tests I'll send in a lab sample or two.
_____________If using Honda MTF (as i will be during my warranty period) what is the ideal intervals for changing in an SI? I believe in over changing vs using it till the last possible moment for peace of mind and longevity on components. Car is still brand new with 300 mi's on it but an oil change is due at 500 for myself and probably a 5k for the MTF if not at 1k. I don't like leaving break in fluids running for very long. The car will be driven on a more spirited side than not plus i'm in Florida so it's a "severe" climate once its broken in passed 1k mi.
Engine oil will be a class iv with 5k intervals. Not sure what brand as this thread has shinned light onto what i should be looking out for.
doing an oil change at 500 miles? Do what you'd like, but the engine has a good amount of moly in it which helps with break in. Draining it early would be counterproductive in my opinionCar is still brand new with 300 mi's on it but an oil change is due at 500 for myself
Honda does not use a special "break-in" oil loaded with moly. What they do is slather engine parts with an assembly lube to prevent scuffing during manufacture. This is what accounts for the high moly content in UOAs of first-change Honda oils.
Typically, the assembly lube is nothing more than a regular motor oil mixed with some molybdenum disulfide paste (yes, that's really all it is). Pro Honda Moly 60 paste is actually recommended in OEM Honda service manuals as the special ingredient to use when creating their recommended assembly lube.
