dpetro1
@trustdetruction provided the correct oem Honda part# for each. The clutch bleeder is m8x1.25
Truly wish I could provide the right info here, but I don't have the answer in this case. I'd be in the same boat if people posted different sizing.@webby can you help?
Thanks @webbyTruly wish I could provide the right info here, but I don't have the answer in this case. I'd be in the same boat if people posted different sizing.
I haven't even opened the packages but they don't look right.@JonnyRotten
What is wrong with the ones you ordered?
Thanks for the verification @ron v. Thankfully that's the one I got for the slave cylinder.
No, I haven't yet. Hopefully soon though.Have u done the delete yet? Thoughts?
To be honest, there's not much of a difference between stainless steel line brands besides price and the brand shown. This is what I have (purchased Aug 2014) and it is only a fraction of the cost,
View: https://www.amazon.com/Russell-684740-Brake-Line-Kit/dp/B001B82GES/ref=sr_1_1?s=automotive&ie=UTF8&qid=1488637336&vehicle=2007-59-752-823--7-6-5-8068-2449-1-1-2825--1-0&sr=1-1&ymm=2007%3Ahonda%3Acivic&keywords=stainless+steel+clutch+line
I have a Russell clutch line for my Si and Goodridge for my E36 M3.
Has anyone had any experience with the K-Tuned stainless steel clutch line?
http://k-tuned.3dcartstores.com/Stainless-Steel-Clutch-Line-Kit_p_44.html
The K-Tuned stainless steel line replaces the whole clutch line from the master cylinder to the slave cylinder. It becomes one line which is nice.I have the Russell myself and love it for the price. Easy to install to if you have an aftermarket intake.
I finally took out my air box to have a look at where the CMC is located and to see where the clutch line is routed so I could decide whether or not to use the K-Tuned SS line that I purchased, seeing as it is designed to replace the whole line.The K-Tuned stainless steel line replaces the whole clutch line from the master cylinder to the slave cylinder. It becomes one line which is nice.
That's why I was asking if anyone had any experience installing it.
I'm wondering how everything lines up etc. or if anyone had any difficulty with replacing the whole line on our cars.
Finally got around to doing the CDV delete.Have u done the delete yet? Thoughts?
I couldn't get the cap off either, so I ended up tapping it out from the back with a mallet and screwdriver.I would have to say that the hardest part of this whole process is first as everyone says, getting the C clip off. I went and bought a set of picks as shown by the OP and those work well. You just have to keep working at it. I think the problem I was having was that I was trying to pry the clip from underneath one of the ends. Once I pushed the pointy tip in from the top of the clip, it popped right out.
After that I had a hell of a time getting the cap off. My smaller set of needle nose pliers were a little worn out at the tip so they wouldn't grip the cap to pull it out.
The third and final PITA was getting the actual CDV out of the body of the slave cylinder. I used a thin piece of wire that I pushed through from the end where the hydraulic line attaches to push it out.
Hope that helps anyone that is considering doing the CDV delete.
I would have to agree with everyone else that this is a great mod.
I don't know why I waited so long to do this, but the clutch feels awesome now! I did it by myself too with a vacuum cleaner attachment stuck inside a tennis shoe wedged up against my seat. I got the idea from a friend of mine. It worked great considering I didn't have anyone to help me at the time.
