That's what you get for asking a cat to help you @ron vUgh. Done. No pics as I almost strangled a cat in frustration. But it's done.
To be honest, there's not much of a difference between stainless steel line brands besides price and the brand shown. This is what I have (purchased Aug 2014) and it is only a fraction of the cost,Has anyone had any experience with the K-Tuned stainless steel clutch line?
http://k-tuned.3dcartstores.com/Stainless-Steel-Clutch-Line-Kit_p_44.html
I tried to get the clip out for like 30 minutes the other day. Just would not come out. I'm give it another shot in a few weeks when I have a vacation.
I've debated doing this before I leave but since I have quite a bit to get done this week, doesn't look like I'll have time.....
Googling flare wrenches, lolDo it. It'll take you 2 hours tops and then you'll be like "you were right Ron". Use flare wrenches!!!!
@bauer311 I thought the same thing about the flare wrench. Mine is a year older but I am sure that part has not changed. After trying for a while with crescent wrenches I could not get that nut loose. If you really don't want to spend the $6 for a flare nut wrench, maybe you could rent one from an Autozone store. But trust me, it will make things a lot easier changing the clutch line. Just in case you were curious where I got mine, here is the link...
https://www.lowes.com/pd/Kobalt-9mm-x-10mm-Flare-Nut-Open-End-Wrench/50142254
I won't be free till like the beginning of next month but I'll help u. It's not hard at all. The hardest part for me was the clip.
If the car is stock I doubt it's out. but I would check where the cap is that holds the valve in. There will probably be some marks of someone trying to take out that clip. And for me it felt like the tranny was slipping at high rpm shifting.
I'd never make fun of someone for keeping there car stock cause the way I see it I'm the one spending money I don't have on stuff I don't really need. It's a drug.
If it's really gonna make that much difference, I would have thought bring pretty new ('15) I would be good. Thanks for the tip @ron_v & @ sarcras.@bauer311 I thought the same thing about the flare wrench. Mine is a year older but I am sure that part has not changed. After trying for a while with crescent wrenches I could not get that nut loose. If you really don't want to spend the $6 for a flare nut wrench, maybe you could rent one from an Autozone store. But trust me, it will make things a lot easier changing the clutch line. Just in case you were curious where I got mine, here is the link...
