9thgizzyguy
- 455
- Vehicle Model
- Civic si RR
- Body Style
- Coupe
now does any of this change when we disengauge traction control ?
with the valve in i mean .
thnks for the infoThe only picture I see in post 1 is the picture of the pick tools. Anyone else unable to see the other images?
Yep, that would be the issue then. If you could do that, it would be great.Are you using a work computer? Those images are linked from fb. "fbcdn-sphotos....". I can re-attach the pics directly to the forum.
Let us know what you find out. Bleeding the clutch would be the cheapest and first option I would take.ok so i did the cdv delete and now im smelling my clutch burning i know how to drive so im wondering if i didnt bleed the clutch right any suggestions????
why dot 4 iinstead of dot 3???You'll probably notice a much bigger difference if you ad a Dot4 brake fluid in your cmc and installing a stainless steel clutch line.
Nice DIY.
Higher boiling point and I believe also higher resistance to absorbing moisture.why dot 4 iinstead of dot 3???
Considering you said it was grabbing close to the floor, I'm gonna go ahead and say you need to bleed it again. Engagement point should be higher up than thatok so i did the cdv delete and now im smelling my clutch burning i know how to drive so im wondering if i didnt bleed the clutch right any suggestions????
clip is easy to get out,all you need is a small pick and flat head.Well, tried it today and after trying to get the clip out for an hour, I give up. Had to reassemble everything which is only moderately difficult because of the tight space to work in, but that clip just would not come out. Fk Honda for not using a snap ring with the little holes in it for use with snap ring pliers (which I do own).
When you say add, you mean remove the Dot3 first, right?You'll probably notice a much bigger difference if you ad a Dot4 brake fluid in your cmc and installing a stainless steel clutch line.
Nice DIY.
I've wondered why when I do lazy shifts they're sometimes all f'd up. Different release points, etc. TBH, I've found that the best shifts are when still depressing the pedal, almost at the bottom. This is a must do mod! Now, it's been about 30 years since I bled a clutch, but IIRC, it's have donkey pumper in the car, pump the clutch several times 'til pedal is at top of travel, loosen bolt, have donkey tell you when it's to the floor, quickly tighten bolt, do it again 'til no bubbles in jar of fluid. DId I forget anything?Lol. Yeah.
