sunofwolf
- 178
- Vehicle Model
- Civic SI
- Body Style
- Coupe
How do you do that?
Is it locked to your vehicle yet?this Hondata is still in Business, there is no base tune loaded.
Looks like I loaded the map with the stock tuned with 6000 launch limit. Well lets try it out-Oh maybe I have to lock the ECU first using the desktop Ug- is that right?this Hondata is still in Business, there is no base tune loaded. Ok it poped up to reflash! Which one is best for a stock si 2013? Looks like the stock tuned with 6000rpm Launch limit-what will this tune do? Is it safe to run? Do you have to lock the ecu to load the base maps-I can't seem to load them?
No- I guess I have to bring my desktop out to the car to lock the ecu then I can load the base map Is that right? Will the base map do anything to help the car like maybe fix the shifter lag? the stock reflash is a bit different then the 6000 launch flash. I just load the stock reflash non carb.Is it locked to your vehicle yet?
Nope. Desktop doesn't need to come outside.No- I guess I have to bring my desktop out to the car to lock the ecu then I can load the base map Is that right? Will the base map do anything to help the car like maybe fix the shifter lag?
No, that's not what it means. You can lock it to the car by plugging it into the OBD port even without a laptop.Where does the stock tune go-is it saved by Hondata. I did notice that redline Higher, if it gets rid of rev hang that's good. The info says you must lock the car to load tune that means bring desk top to car first time.
