- 57,122
- 24,253
plus sgt.Mecca has 18 inch wheels=big difference; but i would love to see a front view
What kind of exhaust do you have? My front end doesn't seen low because of hfp front "skirts", its not a full lip. Id like to see a company start making lip kits for 2012 coupe's. My under body and exhaust are pretty roughed up because the car sits low as it is. Im planning to run 16" snow tires for this winter. With minor adjustment, ill make it work.
SgtMecca what are you planning on doing for your snow tires? I'm going with 16" as well but I'm not sure if I'm just going to buy a set of Honda steel rims or get a set of cheap Aluminum wheels to put the X-ice on. I can't decide.What kind of exhaust do you have? My front end doesn't seen low because of hfp front "skirts", its not a full lip. Id like to see a company start making lip kits for 2012 coupe's. My under body and exhaust are pretty roughed up because the car sits low as it is. Im planning to run 16" snow tires for this winter. With minor adjustment, ill make it work.
I'm with ya on that vinnydanks! I hate winter. It's no fun to drive in and everything gets filthy!it just makes me sad that winterrs coming aka soon to be wintermode![]()
My roof rack is gunna go on and my car is going to be raised soonI'm with ya on that vinnydanks! I hate winter. It's no fun to drive in and everything gets filthy!![]()
from the description:Has anyon else seen the duraflex lip kit for the 2012?
- being that it's partially fiberglass, and requires all of the prep work to fit...plus paint... you're better off buying the hfp kit from collegehillshonda. No prep, it's painted from the factory with honda paint...and potentially cheaper than that kit after it's all said and done.We want all consumers to know that there will always be minor sanding, shaving, cutting, and/or filling prior to installing Extreme Dimensions parts. Also, the black primer finish must be sanded and other prep work will be required prior to painting.
What did you use to hold your license plate?
