- 57,145
- 24,327
That's going to make a lot of SI owners happy. Thanks Jason.
Thanks for the update. What did the new rear panel cost? The first two parts were just under $50 each here in Canada.
Was the rubbing that noticeable, or could someone live with it for awhile? In the video he says its very slight. I just wanted to confirm. I'm picking the two original parts up tomorrow night.
Mine came with an extra mounting bracket. If yours came with an extra hinge assembly, then you obviously only need one.Ok. I picked up my parts tonight. I ordered part numbers 83460-TR0-G01ZB (hinge assembly) and 83450-TR7-C02ZA (top coat).
My question is that the top coat appears to have the hinge assembly already on it. I may be missing something so maybe you have a look at these two pictures and let me know what you think.
Remove the excess mounting bracket from your new Top Coat Assembly.
To do so, remove all five screws (green arrows), then use your dash removal trim tool to push inward a mounting clip (blue arrows), as indentified in the photos below. The clips are in-between the fabric and the bracket. You only need to push one in, then the entire bracket will come loose.
Note: Honda included two mounting brackets with the Si; one attached to the Top Coat Assembly and one attached to the Hinge Assembly. You only need one bracket.
I do not know if Honda included it by accident or not, so I'm going to assume that this is standard operating procedure.
I have no idea why they gave you a second hinge assembly. The part numbers don't overlap parts. But then again, I have no idea why Honda gave me two mounting brackets.That's what I thought. I just wanted to make sure the hinge assembly on its own wasn't different than the one on the top coat.
So I guess this cuts the price of this mod in half......if the dealer takes the hinge assembly back.
No wonder the parts are backordered...they're giving extras away for free![]()
Well you weren't supposed to receive two. The part numbers don't include two, so buying only one part will only serve to disappoint someone when Honda finally wises up.I know. It makes it hard for people to order when you have no idea what's going to be in the box. I would maybe suggest only ordering the top coat and see what's in the box before ordering the hinge assembly. It might save the hassle of returning it.
You can try returning the extra part, but I don't know if you're going to get a refund since you received the parts your ordered. Just best to sell it here I suppose.
Including shipping, under $97 from College Hills Honda.if i can ask how much have you guys paid for your parts
The first post lists the part numbers, and each part number is linked to College Hills Honda so that you can you see the price per part.ok i was just wanting to make sure cause i thought that it seemed a little high
When I pick up the rear trim panel I'll try to return the hinge assembly. It's almost $50 here in Canada. I'll post what they say.
