KennyGS
How may I help?
Truth was making his first trip to the Dragon and thought I should be impressed that in some sections he hit 45mph.![]()
Oh well, it was his first time after all.
Oh, Billy. I forgot. LOLI wonder why drives that VW? is he my doppelganger![]()
Murdering that RF tire!
I knew the mod bug would bite.yeah I hate that I couldn't make it :sad:
My rubbers (michelin PSS) are coming in tomorrow, getting them installed in April.
Keep in mind the last two years I was on oem tires, stock suspension with nothing more than an alignment and bigger rear swaybar. Now imagine when I actually put good tires on it and decide to mod the suspension (racecomp yellow springs, gtworx bilsteins)![]()
I give you the license plate of the knife throwers
http://killboy.photoreflect.com/store/Orderpage.aspx?pi=04RK01UD050237&po=237&pc=1088
I definitely think you should. If for no other reason, JUST to be the most annoying thorn in their side since the ATF destroyed their still.
Bled the system. Cmc and slave cylinder are working like they should. It is something in the clutch assembly. Thinking the bearing is gone or some other issue. Trying to decide if I want to tackle it myself.
Awesome! I smell a lawsuit!!!!![]()
What do you say Mike ? Are you going to pursue it?I definitely think you should. If for no other reason, JUST to be the most annoying thorn in their side since the ATF destroyed their still.
... Not too worried about suing, though it would be cool if the perpetraitor covered my deductible, but @ $250, its probably not worth pursuing. I mean, look at what he was driving! Logic tells me the dude's broke as a joke anyhow.It is hard to get into gear. Sometimes I can't push the clutch in all the way.Rich,
After hearing a bit about your problem. I'm leaning on the diagnosis of a thrown clutch disc spring.
You say you can't get into any gear, correct? (Or it is very difficult to get into gear.)
