John Kirkland
Member
- 6
- 0
Considering there is a coolant passage through that gasket, and all the studs from the very hot head to intake manifold touch the manifold itself, a small gasket is not going to "insulate" all that heat away. On top of that, at WOT, you have an air flow (air is a terrible conductor of heat btw) moving so fast that it does not have time to "grab" any heat off of anything.Lol. Thermal gaskets do more than you think. I guess you need to do more research about thermal conductivity before saying negative comments without using actual proofs about it.
