Mikex18
i have one...not installed yet lollTotally!!! I think I may be the first 9th gen with an after market fuel rail![]()
i have the same oness they look good
you have the K-tune one?? Also, you may want to change the fuel hose cause the OEM one will not fit into the end connector of your fuel rail.i have one...not installed yet loll
Yeap he he this boy will be riding with stylehahah!!! I had no clue they made those. That's awesome!
This is what I got for my son Dylan
You have the unversal or the one for efi systems?? Becsuse there is two models one for kswaps into eg/ek/integra and one for the 2006+ civic si they come with a fitng made for the fuel lineHere's a pic of the Spoon Reservoir covers installedMikex18 You can see the new fuel hose installed with this pic as well:
I ordered through the main company RECARO via email.Where do they sell these? I'm having a kid soon and I need one!
I got the one with the EFI fitting with the gauge.You have the unversal or the one for efi systems?? Becsuse there is two models one for kswaps into eg/ek/integra and one for the 2006+ civic si they come with a fitng made for the fuel line
Univesal
http://k-tuned.3dcartstores.com/Fuel-Rail-Center-Mount-Gauge_p_62.html
Efi systems
http://k-tuned.3dcartstores.com/Fuel-Rail-Center-Mount-Gauge-Kit-w-EFI-fittings_p_38.html
Sleepingpanda Maybe I was one of the unlucky ones, but I did the same thing you just described, and unfortunately it didn't work, as the hose's diameter wasn't big enough to go over the end link of the fuel rail. FXRob helped me with the installation and he was able to connect the hose, but it ended up leaking fuel. Therefore, we went with plan B and use a bigger hose instead and it worked perfectly.You need to unclip the factory fuel line from its bracket. And pull it towards the front more. Then it will fit just fine. And look a tad better than a autozone hose and worm clamp. Lol
Thank you for the better explanation brotha FXRobThe factory line length was fine, the issue was with the tolerances of the K-tuned rail having a slightly smaller diameter which allowed fuel to drip past the o-ring on the factory line. Instead of playing with different sized o-rings which may or may not have solved the issue I had some 5/16" fuel hose which I knew wasn't going to leak and be safe!
They're definitely more beefier and since the Eibach sway bars are thicker; I wanted better end links. The OEM ones started to wear out on me.Do end links make a big difference or is it just so the stock ones don't wear out?
