WITH THE LIGHT ICON POINTING DOWN LIKE SO:
Pin 5- Positive, this completes the circuit for the on/off function
Pin 4- Power for switch
Pin 3- GROUND for Switch
Pin 2- Power/Live wire for illumination
Pin 1- GROUND for illumination
Maybe this diagram will help you out.....by any chance can you tell me exactly were everything is suppose to get connected? I can't even get the switch to light up and I have everything attached like you had in your photo. does the positive "to light need to be connected to something for it to work? or just for testing sake can I just connect the "feed" wires to the battery and ground to the frame? I am just lost, the diagram posted really doesn't help total noobs what can go were or how to test this.
also another question for this image are all three center prongs soldered together?
http://i.imgur.com/k5eRN7Zl.jpg
but the it shows that he connect pins 1&3 2&4 with electrical tape.
I am just really confused
uhhh... isnt fuse 23 ignition HAC? lol ambient lighting fuse is only 7.5A and it's #35Dtaggart
The adapter will go into the slot, then the fuse into the adapter.
And yes, slot 23 comes on with the ignition, and turns off with it too.
Slot 23 is used for Honda's ambient lighting kit, so it's perfect for this application
Check the illuminated door sill DIY to see which wires control dome lights.Well I hooked it all up and its banging. 23 turns on when you turn the key one click. AlienPrime is right 35 is Ambient, 23 work just as well though.
My next project is tying my lights in with my domes
Thanks for all the help really appreciate it.
if the 5th pin wasnt making connection this would not have caused a short. Pin 4 and 3 could have been connected somehow. Or your feed was looped to a grounded ground. Or you were feeding power into a ground without a resistive load :/Well, I just spent a few hours trouble shooting this dam switch and I will post this here in case anyone else ever has this problem. After fixing a rattle, I put my dash back together and plugged all my switches back in only to find out that my ambient lights were not working. I checked the fuse and it was blown. replaced it only to have it blow again. So i figure there has got to be a short. I check and double check all wires and could not figure it out for the life of me. Finally I brought the switch into the house and took it apart. Thanks to @323 for putting pictures and showing me that this could be done. I tested all the wiring in the switch and could get the light in the button to work, but could not get my LED that was controlled by the switch to work. I ended up narrowing it down to pin #5 which is where the power supply comes out of the switch. I took a small pin and just bent the small metal contacts (the actual switch contacts) upwards hoping that it would make a more solid connection and maybe solve the problem. It worked. Yahoo!
It was the little metal piece that has two prongs that moves into position when clicked on.if the 5th pin wasnt making connection this would not have caused a short. Pin 4 and 3 could have been connected somehow. Or your feed was looped to a grounded ground. Or you were feeding power into a ground without a resistive load :/
Ya, maybe the contact was so weak and inconsistent that it cause the short. ???if the 5th pin wasnt making connection this would not have caused a short. Pin 4 and 3 could have been connected somehow. Or your feed was looped to a grounded ground. Or you were feeding power into a ground without a resistive load :/
