Nevtec
I put some vinyl on today, I think it looks pretty good for as cheap as it was.
Pretty sure thats just how the warm up phase for our cars is. When the ecu is in warm up mode (cold start or right after you start it) it runs pretty rich (exhaust pops) and is really unresponsive, I pretty much had to floor it to rev to 5k. Out of warm up its fine though. Its normal.Yes i noticed more response in the revs i replaced it trying to get rid or a bad cat/backfire possibly???????? And after install only when she starts cold it the exhaust pops when u rev it and its boggy like its being restricted by one of the cats !!!!! Im thinkin the primary/downpipe cat is the culprit lol back to the drawing board all for the love of hondas lol
Did you grease the end links?I finally got around to installing my 24mm progress bar a few days ago, but it was making a noise at low speeds. This morning I got under there again and tightened the end links, but the threaded bolt sheared right in half... So I scrapped the adjustable end links and put the stock ones back on. Noise is gone. I guess I'll never find out the exact cause of the noise. But it was either the links weren't adjusted right or the link bolts weren't tight enough.
As for my impression of the RSB, I took a shot in the dark at guessing which end was the stiffer setting, but have since learned that I chose the softest setting. I can still feel the difference from stock, but I'm going to try the stiffer setting out tomorrow maybe.
No, never thought I had to. Have people been doing that?Did you grease the end links?
I think you're supposed to, I greased mine when I changed them.No, never thought I had to. Have people been doing that?
OK thanks, I'll add that to the list of possible causes for next time.I think you're supposed to, I greased mine when I changed them.
Me too. Just wish they were less $$$$. They're the only black one's I've seen advertized anywhere.I'm liking the black symbols. Nicely done.
kplayground had a valentines day sale on them, they were advertised in red but i asked if they would do the same in black. They said no problem (super nice fellas there)Me too. Just wish they were less $$$$. They're the only black one's I've seen advertized anywhere.
