Kevv_Si
Everything is on there tight I doubled checked and I pulled the intake off the turbo last night to check for oil residue cause that would be the first thing you will see if the turbo was bad and everything was spotless soo it's not the turbo. It's precision's journal bearing turbo's that just smoke a lot when you start the car and goes away when the car is driven. I am confident in our install so I'm just going to put everything back together and fix the wastegate (left 15psi worth of springs in it lol) and just enjoy the carHave you checked all of your oil fittings to make sure you don't have a small leak somewhere? I know it sounds trivial but I'd hate for you to pull the whole thing apart just to find out you had one fitting that was loose. Is the smoke coming from under the car or out of the exhaust?
mine changed for daylight savings automatically. I thought I cars were smart!
