DW tires installed today.
The Nankang's? If you meant those then the answer is no. I wouldn't trust selling them to someone.Selling the others?
Junked them. The 18" tires (nankang) that were on the BBS wheels were old.What'd you do with the others. Junked them? Weren't they brand new?
@death_roll @07TLX @webby
What tire pressure would you run in the DW's?
Currently they have 35lbs (cold). Of course its a bit more when hot.
I'm selling the stock OEM WRX tires tho
Yeah... Getting a text from a random number of my car freaked me out a bit.. lolhunting subies...
Parts update:
- Last night before the above meet I installed the Perrin Shifter Stop
From Perrin's website
ESSENTIAL MOD
Due to the slop of the internals in the transmission, there is an unacceptable amount of horizontal slop within the 1st- and 2nd- gear shift gates. What should be little to no movement ends up being nearly 1.0 inch of play. This makes for an unnatural placement of shift gates and a lost feeling of which gear you are in. The PERRIN Shifter Stop removes this play, reducing the horizontal movement to 0.12 inches. This makes for a solid connection between the driver and transmission.
Source: http://perrinperformance.com/i-19229535-shifter-stop-for-2015-wrx.html
Yeah I was skeptical but I'm surprised it made a difference.I remember feeling that shifter slop when I test drove the wrx, it was one of my biggest concerns especially considering how tight the Si's gears are. I'm glad a simple part can fix it.
