The 35% looks great but I don't know what sort of hassle the local cops will give you. 70 is very very light. That's all. Just be aware of what you're getting into. Worst case, you get a ticket and have to remove it.
Thanks @PRO CivicThe SiriMoto spacer and gasket does not require cutting of any kind. It is a 100% direct bolt on part.![]()
Thanks @PRO Civic
I may get this instead of P2R then.
Do you think there's a problem with K&N 69 intake? Do I need two gaskets if I install with K&N 69 intake?
Thanks
@webbyIs your battery the original?
No. I'm unable to find out. Everything seems to be fine. The battery is checked fine too. Maybe she's mad when I wanted to start saving $ to get the new coming Civic Type R....Did you figure out what's wrong? I just got stuck at the grocery store. Looks like I have a bad ground. I'm on my way home now to investigate.
@Michal006
