Cmon don’t leave us hangingJust chilling
Long time no see my dear friend. How are you??? Finally got my Kraftwerks kitCmon don’t leave us hanging
I can see that. How were the numbers???
Nicely done. You may want to post your camera info into this thread as well.I spent a few days installing a dash camera system and the auto dimming mirror.
I started by dropping the headliner to make running the wire back to the rear camera easier. Plus, it basically needed to be done to install the mirror harness (the installation instructions basically tell you to just pull down the front but I pulled the whole thing down).
The dash became a convenient spot to store things (please ignore how dirty the car is, I needed/wanted it dirty to make the widows peak on the windshield super easy to see to aide in camera placement; plus, it is pollen season so I'm not bothering too much):
Working on getting the wiring all run:
Rear camera installation (the cord was way longer than really needed so I ran some excess over to the right side and then back to the left and forward along the harness for the sunroof actuator; even then, there were still about 3 loops front to back of excess cable):
Finished placement of the rear camera:
Front camera. Ignore the windshield, I was using a spay bottle with soap water to check if the wiper line would block part of the camera's view; I really hate the odd wiper design on this car, it just made everything more difficult; this was the 3rd one of these camera installs I have done and the wiper issue was by far the biggest pain when it came to determining where I wanted the camera to go for final placement. In the end, I went for higher up and off center to get it into the wiper arc; both of my other camera installs were easy enough to get placed in the center as they had a standard wiper setup.
Finally done after everything was reinstalled (you can see the rear camera in the mirror, it is mounted high enough to not really be much bother in the field of view):
All in all, it was a 1-day job that I spread out over 3 days. Besides, it gave me an excuse to drive my Stealth to work during the nice weather we've been having. But, it is raining now, and should be tomorrow; so, I'll be driving the Civic to work.
28/24 is what is listed as max onlineI havent bought a dash cam yet but I noticed the spot where I would be mounting the dash is always covered in dirt as the wipers never reach that area of the windshield.
Is this an issue?
Also, random question but has anyone bought a larger wiper length to clean their window? Mine are 26 / 24 inches but would 28 / 26 inch be possible? That dirty triangular spot always bothers me.
The dirty area in the center that you mentioned in your post is what I referred to as the "widow's peak" in mine (referring to common hair lines). So, yes, to put the camera centered, it is a problem in my opinion. Although, I'll admit, I did not consider longer wipers as a compensation for reducing the unswept area and bringing the camera more centered. In the end, I offset mine to the left of center to get the camera body high and out of the way (it would have to be fairly low and in the way to get the camera below the widow's peak and centered) and in the wiper's cleaned area. I need to take some pics of mine from the outside to show where it is placed for a better reference for everyone (my car is still pretty dirty though due to the pollen and weather we've been having in VA).I havent bought a dash cam yet but I noticed the spot where I would be mounting the dash is always covered in dirt as the wipers never reach that area of the windshield.
Is this an issue?
