Janz3n
Evening.Morning
Evening.Morning
Busy day just got done eating dinnerEvening.
"ate the bolt"?
Is this a common thing? Will it just end up happening again with the new engine, or is there an actual “fix”?![]()
grid heater fails and drops a bolt into the intake, bolt rolls into cylinder 6. piston eats bolt.
I'm not sure. I've seen it a lot on the internet. There's supposed to be a bulletin for the relay sticking causing this issue. Co worker just replaced the grid heater on a other truck for a grid heater code but it wasn't loose. Lots of stuff on the internet replace this stuff with an upgraded banks intake that removes the heater and relocates it.Is this a common thing? Will it just end up happening again with the new engine, or is there an actual “fix”?
Got the tires mounted and everything... will probably try to do the chain tomorrow. I sat on the frame and it seems to fit okay; I'm curious as to how well it'll steer with these dinner plate wheels.
why would they be putting parts in to your truck?Took the day off for a surgical consult on my knee. Standing in the kitchen making a cup of coffee and I hear someone unlocking my work van and loading parts into the back. Text one of the routing team members and she forgot I was off today. Let’s see how this somehow becomes my fault.
I start and finish my work day at home. Someone swings through around 630am every morning and loads whatever parts I need for my day then takes whatever trash or returns I might have.why would they be putting parts in to your truck?
Ah. So they think youre working. LolI start and finish my work day at home. Someone swings through around 630am every morning and loads whatever parts I need for my day then takes whatever trash or returns I might have.
