Pretty clear that your camera doesn't work past 12:13
So after the 12:13pm alert today.. I left the house around 4pm and no alert.
Came home around 8pm and no alert.
So ******* annoying.
I don't know if your settings are like these?
is it on all motions or only human? Sensitivity high?
3. Detection Type – only human/all motions
4. Sensitivity – low to high
1. Detection Mode
Clearly, it starts with making sure you have the Detection Mode enabled.
2. Activity Zone
Next, you have the Activity Zone configurator. That currently supports a hexagon of 6 points for you to drag around with. It’ll take you a bit of fidgeting to get it right, and the interface might feel a bit clumsy too.
But it works.
If your Activity Zones are inefficiently set up, there might be your instant problem (and solution).
Only Human / Sensitivity 3 (Default)
No activity zones set. When I had all motions enabled I had activity zones as it was alerting too much. But with Only Human I don't have any zones.
Thanks for the help. I might move the doorbell to the opposite side where it's at now. Other side of the front door.. Hmm
