cetromero
What wheel size and offset will those tires go on?
The wheels I was looking at are 17x9 +42
of course you wont rub lolHey does any know if you could get 255/40/r17 with no rubbing stock height?
on stock tires i definetely won't rub, definetely will just look super oddNot quite sure if your being sarcastic.
Hey man I want to get some XXR 531 17x8 but I dont know what offset to choose? I want a little more camber that stock but I want to be flush. I'm going for that look on the black fb6 on Varrstoen es7 page.ohhh yes sorry 18x8 +35 is the safest you can run with no camber/ no roll
and pretty much as close as you can get to flush without camber![]()
Well I plan on using my stock tire I guess I should of mentioned that lol I wanted to get the actual Varrstoen es7's but they only have 17x9 and that's too much stretch for a 215 tire isn't it? And as far as how low probably like 2.5" lower just a small tire tuck.I would suggest the +35 over the +25 just for ease of fitment. You could probably get away with the +25 but it will depend on low/tire size/camber settings/fender work.
With the +35 I think you could run either the stock size tire or even bump up to the 225 width for some extra contact patch without too much trouble.
if you are running stock suspension i can't see any reason you'd rub@Nix or anyone? PLEASE?
