- 25,902
- 10,785
When you take a photo..put it on your computer and look at the properties. It'll tell youI am no photographer and the rules and format confuse me. I also dont want to upset @MrsJrotax101
Are you using PC or Mac?
PCWhen you take a photo..put it on your computer and look at the properties. It'll tell you
How is it connected on the underside? Does the bottom portion below the nut spin when you turn the top one?I got the clutch line off the slave cylinder real easy, but how the heck to I get it off the other end? Do I need to do anything with the clip or just turn the 10mm whatever nut CCW? I don't want to break the hard line that feeds into it. The connection point I'm talking about is next to the vehicle, not the one in the middle. I have pics of the left side by the slave cyclinder (easy disconnect) the middle (no need to disconnect) and the right side (can't get this prick disconnected?) Help!
View attachment 27845 View attachment 27846 View attachment 27847
Just keep at it. Took me like two hours to get it but I was also doing the rbc at the same time so I was exhausted lol. Make sure to take care when taking out the valve. Idk how I did it but I slightly tore the o-ring seal when removing it. Good luck and have patience!Are those picks the only thing people have had success with? Cannot get the c clip out for the life of me.
IIRC there's a small hole on the opposite side of the slave. I just put a thin drill bit or maybe my jewler's screwdriver in there and carefully pushed the valve out from the rear. Came out great.Just keep at it. Took me like two hours to get it but I was also doing the rbc at the same time so I was exhausted lol. Make sure to take care when taking out the valve. Idk how I did it but I slightly tore the o-ring seal when removing it. Good luck and have patience!
ITS NOT JUST ME!? oh thank goodnessI knew there was a reason why I grind 2nd, its designed so you cant quick shift! Good DIY, I'll do this soon!
