Hbr Frght sandpaper is one item that you should toss out. I like them for a lot of stuf but not sandpaper. Go with 3M wet/dry. Lasts forever, where HF's media falls off into your work.What Im using is a silicone carbide dry/wet sand paper from Harbor Freight. Lol.
http://www.harborfreight.com/7-piece-500-grit-silicon-carbide-sanding-sheets-69969-9820.html
Initial impressions are very good for the HFP suspension. I love the stiffer ride, the reduced body roll (it's almost completely gone) and the lowered stance. Sadly, we just went through a cold snap here in Oregon, so we haven't had ideal suspension testing road conditions. I'll definately be making a longer post regarding the HFP suspension in the 2013 Si sedan, but for right now I'll just throw it out there: it fits in the sedan, buy it!
P.s. Oh yeah, I also ordered a Progress 22mm rear swaybar about 3 days ago. It'll go in after Christmas!
I used a 150 grit to remove the remaining paint from the non-stripped surface. Then 500 on bare metal. Then 500 again after priming. I didn't want to go a step finer since these wheels are only for winter so I don't want to put too much effort.I was planning on just putting the snow tires without fixing the curb rashes, but that would have made it an eyesore. Here's another pic after 4 coats of clear.
I really like it too. This is the same paint I used for my valve cover. The paint gives distinct blue shades depending on the lighting.I really like that color
This one is the second wheel btw. The paint I used is Ford Light Blue Enamel.
The light color will only be noticed when the wheels are right under the sun. I'll get these installed when I get the winter tires mounted or the day before the next snowfall. Lol. I installed new valve stems on the painted wheels. I didn't realize they are $2.99 per pair. They are rather cheap.the lighter one looks pretty good, post pics of them on
Lookin nice dar dar maybe u can help me with mine sometimeThe light color will only be noticed when the wheels are right under the sun. I'll get these installed when I get the winter tires mounted or the day before the next snowfall. Lol. I installed new valve stems on the painted wheels. I didn't realize they are $2.99 per pair. They are rather cheap.
One wheel still has a tire on it. I tried removing the tire without damaging it but the tire is dry rotted and the tire bar broke the sidewall. Lol.
Snow plowed with it![]()
Same here, was out shopping last night rally driving around.Lol. I went out and had some fun in the fluffy snow last night, it was great! If only Civics came AWD![]()
