sunofwolf
- 178
- Vehicle Model
- Civic SI
- Body Style
- Coupe
I don't see why you need 3.5 if the pipes are all 3", it simply won't increase the air going into the engine because you stick a bigger filter on there its going to flow at 3" at the exhaust. A engine air flow is only going the same at both ends. If the exhaust was 3.5 inch's you would see a big gain. You can't stuff 3.5 inch into 3" no matter what you do- it's just a waste of dough just like the srt-4 stock filter was 3"-the gain would only come from a cold air filter or a forced air flow like getting air from the fog light-but not good for dirt or water-Win- the stock air filter set up!
I am running a carquest air filter that has shown to add 3HP over the stock one but still filters better than K+N and its dry filter perhaps that all you need to do-it costs like $12 or less. The only thing I have found that really makes any extra power that works well is changing the exhaust every where from the engine to the tips to 3" that matches the stock 3"intake perfectly and a tune. the only way to get more is to add a supercharger or a turbo but that adds on all kinds of new problems not really needed for the DD. CARQUEST air filter, 3" exhaust with high flow cat and tune. That all I am going to do for the engine. add rear 24 sway bar, add buddy shifter-those I can do that right now.
