- 57,142
- 24,326
I've been researching a lot, but I'm still not 100% sure that I'm putting a good machine together. I also am not keen on what video card chipsets are good. Just from parsing through this thread, I see that a lot of you guys have done this several times-- so if you have some time, could you pick out any errors with my parts list? I know how to install parts-- I've just never been in a position to build anything remotely nice.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
CPU Cooler: Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory )
Storage: Western Digital Blue 500 GB 2.5" Solid State Drive (will add more later)
Video Card: MSI Radeon RX 5500 XT 8 GB MECH OC Video Card
Case: Thermaltake Core G21 Tempered Glass Edition ATX Mid Tower Case
Power Supply: SeaSonic FOCUS 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Total: $1039.91![]()
Are there specific games you’re wanting to use this computer for? That will usually determine what graphics card would be best suited
Webby knows all!![]()
You an RGB fan boy?![]()
You didn't ask a question that I thought you'd ask.... What monitor(s) setup is @Honda-Fan using/going to use? That also plays a role into what GPU should be recommended.
For example: My setup -> 27" 1440p 144hz (primary) & 27" 1440p 60hz (secondary) - If I want to game at the highest FPS then a GTX 1660 GPU won't provide me the best gaming experience (of course pending the game).
I still have my GTX 970 in the closet. That thing did a great job at 1080p but once I got the 27" Acer Predator 1440p/144hz it definitely started to chug along.
He just uses Google. That's how he knows everything![]()
So it got delivered today and I'm planning on installing it tonight. Hopefully I can get it figured out fairly easy.Yeah they are pretty powerful units
What do you suggest with his monitor @bootyluvr ... nvidia rtx 2060 6 gig enough for that monitor/refresh? 1080 is a big jump in price clearly
Did you set it to force 5ghz? 2.4 will provide larger range, but slower speedsI got it connected and everything is working but I'm not getting the speeds I should be. I tried to setup the passthrough on my router but not sure if I've done that right or what.
For comparison, unplug the access point and run a test to see what speeds you get.I think it was set on both since we still have a few things that don't run on 5ghz
Will do. Thanks for helping so far.Yeah just walk away for now and relax for a bit. You’ve got a lot of time to return with amazon. Hit me up if I can be of some help
I have buit new gaming pc finally. Can't wait to try it in use
