Janz3n
i dont want to go back to those days lol. worst part is im pretty sure ive got a scale at home to weigh the damn stuff proper.Just going back to your autobody days! That's part of the game![]()
if you're going to keep the car do what you want, assuming it's affordable. Personally wouldn't do it if you were going to sell in a couple years. (You know, sell it to buy a Type R)im debating not putting the badges back on, but that would leave two options. plug the holes some how before putting the resin on or rivet blank metal back on. thoughts ? the amount of work to make this nice is making me hate password jdm.
After all the sanding i see you worked up an appetite.I do not. Why would that be better?
I started sanding this morning with 320 grit. Took a long time. Going to get some courser stuff today.
Yep, lookin' real good. Using a 600 wet/dry or what?It's looking good to me
Interesting photo. Can you tilt it so the excess accumulates in a less visible place?You can see the drips on this part. After trimming with a dremmel tool and hand sanding to create a nice edge.
Finally got all the epoxy that didn't go hard off. View attachment 64995
I was talking about the holes in the gurney flap, not the badges on the car. That's way too much work.if you're going to keep the car do what you want, assuming it's affordable. Personally wouldn't do it if you were going to sell in a couple years. (You know, sell it to buy a Type R)
I've been using a combo of wet and dry varying grits. 120 to get rid of all my bad work and wet 600 for anything worth saving before clear.Yep, lookin' real good. Using a 600 wet/dry or what?
That's where the password jdm bad goes. I drilled out the rivets to remove them to make this job easier.what's the situation with the hole there by the thumb? Is it missing fiber there, or is that just how thick the clear or epoxy is around that spot compared to the low area?
Those are just the hand model I use.You have white hands!![]()
Oh yeah.....welcome to resins! I have a cheap little scale that I use to weigh out the resin and hardener. I still have messed it up plenty of times. I have melted mixing containers before, lol.of course i decided to try and touch out a spot on it yesterday but it had started to get hard when i did it and i messed up part of it. have to sand it down with 120grit again and start over. i also have been mixing the epoxy by eye and not by weight so the first one was too much hardener and it started to smoke in the container and harden real fast. second time i dont think i put enough in and its not hard in the thicker areas yet. i dont know why i make this harder for myself.
If you wet the part with water it will give you a pretty close visual of how the part will come out after a clear coat.Finished wet sanding the back with 600. It's flat now. I'm not sure if I clear coat it now if the dull spots will come out shiny. When I out the epoxy on, these spots look the same as the rest. My issue is I refuse to pour the epoxy on for several reason so I cannot get it perfectly flat without sanding.
I'll end up spraying the back only once I'm done sanding it all and see how it turns out. That way I'll only have to sand one side down if it doesn't look good.
im use spray paint clear. im going to try one side and see if it turns out good. if it doesnt i'll go back to the body shop.Have the painter throw on like 2.5 coats of clear so you have some room to buff
