Janz3n
I want that mirror. I looked into that a while ago.
They are plastic.....you can see 2 broken ones on the left side of the fog lamp.are the tabs made of plastic or metal?
They can be cheap and the install is easy. I think I paid $30 for this one but that was back in 2016 or so. Just get one that comes with the pig tail that connects tot he back of the mirror.I want that mirror. I looked into that a while ago.
Do you know if there are wiring harness differences between the stock auto-dimming mirror and the one with Homelink?
My auto-dimmer is clouding up inside and could likely use a replacement as I prep the Civic to sell. Will be looking at either just the auto-dimmer or Homelink, which ever I can get cheaper.
Thanks for the insightThat I don't know. I've only messed with this one that is a Gentex brand. They supply a couple car manufacturers.
I know newer ones have 5 or 6 wires were mine only has 3 wires. But the 5/6 wire ones have directional arrow, homelink, auto dim and lights all built in to the mirror.
I like it better plain, lolNice. Could get real fancy and do black stitching to do the reverse of the black with red stitching.
Just make it red!I’m reached out to the company that has the material to see if they have the black material.
I’ve cleaned the material on the center arm rest and still looks dirty. Prob needs a replacement. Might try cleaning it again if I can get a hold of a wet-vac cleaning machine.
Looks great. Mine looks awful. I love those red inserts they did for the 2014+ Si’s.I’m reached out to the company that has the material to see if they have the black material.
Maybe….would need to order more material.Just make it red!
Still burning it.....I think about 1qt every 500ish miles.any news on your oil issue?
What do you think a rebuild would cost?any news on your oil issue?
