- 56,749
- 24,151
He acted as if he would attend -talking about 9th
$35 = everyone gets some vtec juice....
I've talked to Brandon about it and I think he's leaning towards this meet as well. I'll talk to Mike about it
yeah because I'll be therebut I won't have the nose-heavy godly chariot
I'm sure your new car will blow the WRX away in terms of handling. Luckily I'll get to drive BRZ's at work. Unfortunately, it won't be "spirited" driving, just around town and down I-40
It'll be interesting to see how Brandon's new car does. Sure it has more power than the Si but now he won't be on star specs and (correct me if I'm wrong on this one) doesn't have a true LSD. However, knowing Brandon I'm sure that GTI will move plenty good
Correct about the lsd. They added braking to the wheel trying to spin. The brakes get a real workout with spirited driving. It was only in the past year or two that the braking was added. I was seriously looking at the gti when I bought the Si, but after a spirited drive that had a lot of tire smoke made up my mind. The salesman was very young and seemed a little shaken after the test drive.I'm sure your new car will blow the WRX away in terms of handling. Luckily I'll get to drive BRZ's at work. Unfortunately, it won't be "spirited" driving, just around town and down I-40
I have the same issues with the e30. Very loud, no radio, no ac, stiff seats with no padding, and very stiff. I am leaning towards the trailer route now. It will also depend on how much work I can get done on it. The rear subframe bushings and dif mount have to be done before any spirited driving.RWD is definitely the most fun to drive. I'm still debating whether or not I should drive the Miata this year. The drive there will be painful (I have back problems, plus at 70 mph it's revving above 3,000 rpm and it's loud) but it would be so much fun up there
I wish Subaru had given the WRX factory LSD. It would be a much better car. A little bit stiffer suspension would help as well
I do need his help/guidance getting the sunroof cassette out and skinning it. Then I get to do the rear subframe bushings. I did just come across a chip wirg 19lb injectors for 93 octane for 200. That is tempting me.you need to recruit mrJ for work
http://9thcivic.com/forum/threads/bmw-m3-track-car.969/page-13#post-47935
I have a close friend who transformed an E30 into a track car. He did the sunroof delete project. he also stuck an E36/M3 powerplant in it. By the time he was finished, it was so beautiful, he didn't want to risk taking it to a track day. You really are going to have to see this car sometime. It'll blow you away.I do need his help/guidance getting the sunroof cassette out and skinning it. Then I get to do the rear subframe bushings. I did just come across a chip wirg 19lb injectors for 93 octane for 200. That is tempting me.
Also looking ar some headers, but the would do better with the chip.
Richard
E30, FA5
Would love to see it. Planning to run the m20 until it quits. Then who knows.I have a close friend who transformed an E30 into a track car. He did the sunroof delete project. he also stuck an E36/M3 powerplant in it. By the time he was finished, it was so beautiful, he didn't want to risk taking it to a track day. You really are going to have to see this car sometime. It'll blow you away.
