CappyKD
Loved reading this thread. It got funny right above . CappyKD. So how's the Buddy Club short shifter package? Is the shift lever the same, shorter, or longer overall, than oem? Reason I wonder is I've heard it sits up an inch higher than stock. I'm already shorter than stock, love it, and have a short shift adapter worth @30% shorter throw, so I wonder how much I might like this. And, side by side, the two cages look identical. Thx.
It sits up a little higher, but the BC knob is recessed more so the knob height is around stock maybe a little taller. I love the shifts!!! If you are already at 30% I don't know how much you will gain. The CT Eng short shift adapter requires cutting a small part of the factory shifter base and not re-attaching a cable to the base, the BC shifter does not. The cages are not identical but they are very close. i can do most shifts with one finger when just cruising, I can't say for sure how that is in comparison to your setup. HTH.
Kirk
