- 57,201
- 24,273
I'm not sure about the wiring off those lights....
Red connector coming off the ballast... That should plug into the low beam stock wiring in your car, or your hid wire harness. Are you using a wire harness?
Edit / check this 2nd vid for an example
http://9thcivic.com/forum/threads/2012-civic-hid-retrofit-headlight-installation.2531/
