- 10,261
- 6,970
- Vehicle Model
- Toyota Tacoma TRD Sport
- Body Style
- @bootyluvr hates hatches
Soooooo lots to digest here. I drained and measured the oil that was in the car. Had slightly below 3qts without dropping the filter. Put the oil back in the motor and happened to have another qt laying around so that got added. Dipstick now reads in between the dots and should be 4qts. Looks like I’ll be adding a qt a month.
Started looking around some more as the rear motor mount was a little wet. Had some brown-ish color liquid, similar to oil. Wiped that dry and will keep an eye on it. Above the motor mount is dry.
Looking beyond the motor mount I saw that there is a missing bolt on the oil pan. Again….dry around the area and no active leak. Yellow is the missing bolt….green is a normal pan bolt.
Looked around some more and see what looks to be some JB Weld on the side of the oil pan. I’m guessing somehow the pan got damaged and a cheap fix was done. This area is right above the subframe so no F-ing clue how the pan would have been damaged. No leak around that area either.
Area in between the red arrows is the JB Weld looking stuff. Hard to see but you can see the black color change from the silver pan.
Here are some other pics that show a clean block and the motor mount before I wiped it clean. You can see a black oil pan gasket which looks pretty fresh?
